So which are decent OEM-type motor and transmission mounts?
Mebsuta
9:31 AM
Khemi, Stygia
Which are decent OEM-type rubber motor and transmission mounts?
I used an Anchor transmission mount my RR, but I am hearing bad things. The other choices are DEA and Westar. What's something that will act about like original without spending $100 on a block of rubber and steel? I don't drag race; just cruise my old beater around. Thanks.
Poly loc's from shumacher, and they are pricey, but the last mount you'll ever need!! If you look at the bolt that goes thru the mount and k frame, you'll notice that it is a 3/8 bolt, shumacher uses a 1/2 inch grade 8 bolt. Also, with the 3/8 bolt, you can watch the engine lift to the passenger side, not so with the 1/2 inch, and that lost torque due to engine rock is now going to the tires....just something to think about. Get the urethane trans mount also.
anchors are cheep std mounts,but really about the same as the originals.they will work for stock aplications for crusing,but will break just like the stock mounts.
