- 6:17 AM
- May 14, 2011
- On the Ridge, TN
Well, we're in East BF here, so I settled for a good old set of Autolite coppers #85.I tried the Autolite racing plug,I use a regular NGK for $20 a set.
Went in fine, used some dielectric grease on the boots to make sure I was seating them all the way (no mean feat with these #$%#@$% Hedman headers), checked over everything I could think of visually.
Double-checked wiring through the firewall next to the new flex line for the oil pressure gauge to make sure I didn't ground something accidentally.
Then I hit it.
Started easy and ran without protest. I could get out of the car within the minute, since it idled by itself like it usually does (no choke, so that's pretty cool).
I let it run a bit to warm up at the higher idle I had to set it at last time to keep it running; I ran the timing light around all 8 wires to check for strobing, which turned out ok.
After about 5 minutes of this and that, I grabbed a flat blade and backed the idle back down to its' normal 800RPM, where it sat fine without protest.
Goosed it a few times over 3000RPM gingerly; no fuss.
Put the !$^%&$^ air cleaner back on it, shut the hood and called it a day,
Sheesh.
I reckon a road test will confirm, but it acts normally again.
I have no idea what I did to "fix" it.
None whatsoever.
