PolaraFury
Hello,
Did a 500ci B block build. The only thing left from the original motor is the block. Roller cam with hyd roller lifters, roller rockers and 440 source stealth heads.
Got it to fire up and run for about a minute and it stalled out.
(Rebuilt Holley 800 DF/DP running on electric fuel pump. Had to do some float adjustment because fuel was pouring into the secondaries.)
Now it will fire but, wont stay running and it backfires through the carb.
INITIALLY I had the timing set at TDC and moved the distributor back and forth until it started.
Backfiring through the carb should be a timing issue. I’m 99.9% certain my initial timing with the distributor and cam gear are correct.
A quick question and I’m open to advice
What direction do I rotate the distributor to advance and retard the timing?
Thank you
Thank you
