Steering Rag Joint and Water Valve
plumcharger
6:00 PM
Iowa
I have a 66 Charger with a 383, power steering and factory air if that makes any difference. I am in need of a steering rag joint (the joint between the steering shaft and steering box). I have not had any luck finding one on the internet. Does anyone know where I might be able to locate one at a reasonable price.
I am also having difficulty locating a water valve. I purchased one off Ebay, but it ended up be a Chrysler model which operates in reverse of the one I need. The inlet and outlet on the valve I bough are vertical to each other and I believe the Charger valves were horizontal. Does anyone have one of these they are willing to part with?
Thank you for any help in advance.
Darren
Parts questioned in this thread have been found. Thank you.
