suggestion - B body monthly tech challenge
Website Suggestions and Questions
  1. Aeronet
    Aeronet Well-Known Member
    961
    1098
    Nov 7, 2018
    Wagoner, OK
    Local Time:
    12:16 AM
    In my defense, this is the first car I've owned with points, and, I had replaced the points and condenser 2 months prior to the event. Now, I just replace the points and keep a known good condenser with me in case this happens again.
  2. moparwacko
    moparwacko MASSIVE GOLD MEMBER FBBO Gold Member
    1,973
    4831
    Mar 14, 2015
    Pa
    Local Time:
    1:16 AM
    Check your ballast resistor to make sure it's the right ohms, otherwise you're going to continue to burn up points and condensors.
    Learn how to "read" your points, all burnt, center burnt, pitted, etc. They all mean something.
    And make sure your date carries a nail file, trust me on that one.
  3. Aeronet
    961
    1098
    Nov 7, 2018
    Wagoner, OK
    Local Time:
    12:16 AM
    This happened 3 years ago. It was a case of a defective part. I've read on other forums that the quality of condensors isn't what it used to be.
    I change the points once a year whether they need it or not.
    I have kept the old points. I keep a spare set in the car just in case.
    I'll take a look at some of the old ones to see what they look like. I haven't noticed anything outstanding other than wear.
    Now, reading spark plugs...that's something I've been working on. I may start a thread about it one of these days.
    I'll see if some of the old shop manuals I have contain anything about reading points.
    Reading points. Talk about esoteric knowledge.
  4. munger77
    munger77 FBBO Gold Member FBBO Gold Member
    332
    255
    Apr 25, 2015
    Atlanta, GA
    Local Time:
    1:16 AM
    Aeronet, nice one!
    Mopar74; thanks for helping so many on this forum, you are right too, a lot of people already do that here.I thought it might be a cool way to collect a database of "known gremlins" when it comes to mopars. But you are all correct, we do a lot of it already.
    • Thanks! Thanks! x 1
    • SgtSuperbird
      SgtSuperbird Well-Known Member
      220
      373
      Jun 4, 2019
      Clay, MI
      Local Time:
      1:16 AM
      That will happen too, if the nut on the terminal end of the condenser comes loose. Don't ask me how I know.
    • Ernie ingling
      Ernie ingling Well-Known Member
      379
      271
      Jun 8, 2019
      Cocoa Fla
      Local Time:
      1:16 AM
      Use Echlin points and cond never fail. But carry a spare.
      • Agree Agree x 1
      • Aeronet
        961
        1098
        Nov 7, 2018
        Wagoner, OK
        Local Time:
        12:16 AM
        Echlin is in it now. Autozone condenser failed.
        Thanks.
      • Aeronet
        961
        1098
        Nov 7, 2018
        Wagoner, OK
        Local Time:
        12:16 AM
        munger77. I thought of another one. This happened about 2 months ago.
        1969 Dodge Coronet. 318 904 8 1/4. Factory stock.
        One Saturday morning I went out to start the car and...nothing.
        Hints: dome light was nice and bright. Type of ignition is irrelevant.
        There is a bonus question if you solve this.
      • BB BELLA
        BB BELLA Well-Known Member
        466
        480
        Jul 27, 2018
        Severn Bridge
        Local Time:
        1:16 AM
        you left the keys in the house!
        • Agree Agree x 1
        • moparwacko
          1,973
          4831
          Mar 14, 2015
          Pa
          Local Time:
          1:16 AM
          Nuetral safety switch
        • Aeronet
          961
          1098
          Nov 7, 2018
          Wagoner, OK
          Local Time:
          12:16 AM
          Yes, moparwacko, you are correct.
          Bonus question: can the Neutral Safety Switch be bypassed?
        • Photon440
          Photon440 FBBO Gold Member FBBO Gold Member
          11,112
          11735
          Mar 14, 2012
          Surrey, B.C. Canada
          Local Time:
          10:16 PM
          Back when I had the torqueflite out and a four speed in place, I bypassed the neutral safety switch by sticking a piece of wire in the plug slots.
        • Aeronet
          961
          1098
          Nov 7, 2018
          Wagoner, OK
          Local Time:
          12:16 AM
          Good to know. There is another way also.
        • Aeronet
          961
          1098
          Nov 7, 2018
          Wagoner, OK
          Local Time:
          12:16 AM
          Here's another one. Happened about four years ago. Same car. 904 TF. I lost 3rd gear. 1st, 2nd, and reverse were fine. It just wouldn't shift into 3rd. There was one cause and one cause only.
          Review the Torqueflite sytems to find the answer.
        • moparwacko
          1,973
          4831
          Mar 14, 2015
          Pa
          Local Time:
          1:16 AM
          Terminal on starter relay
        • Aeronet
          961
          1098
          Nov 7, 2018
          Wagoner, OK
          Local Time:
          12:16 AM
          moparwacko, yep.
        • 451Mopar
          451Mopar Well-Known Member
          2,414
          1738
          Oct 25, 2011
          Aurora, CO
          Local Time:
          11:16 PM
          Had that happen to a 727. It was not the front clutch pack, but a crack in the valve body. Some JB Weld fixed it (I was 200 miles from home at the time.)
        • Aeronet
          961
          1098
          Nov 7, 2018
          Wagoner, OK
          Local Time:
          12:16 AM
          Interesting. Me, the front clutch pack burned up.
          How did the valve body crack?
        • 451Mopar
          2,414
          1738
          Oct 25, 2011
          Aurora, CO
          Local Time:
          11:16 PM
          one of the fluid passage walls failed, really more like a small chunk of the aluminum wall broke out.
          This was on a fairly fresh rebuild with one of the low buck shift kits installed. Trans would bind up between 1st and 2nd gear at WOT, but sounded cool because it would bark the tires when shifting. This was my '69 Polara 4-door with a stock 318.
        • Aeronet
          961
          1098
          Nov 7, 2018
          Wagoner, OK
          Local Time:
          12:16 AM
          Was the shift kit one where you drilled down one of the walls? I installed a B&M transpak in a 727 in the '90s and I seem to remember drilling a wall in the valve body.
        1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
          By continuing to use this site, you are consenting to our use of cookies.
