DWinTX
Hey, it rhymes!
We're doing a cam/intake/carb upgrade on my son's 318 poly/727 65 Coronet. We're going from a stock 2-BBL setup to the Holley on top of a Weiand 7503. Can anyone tell me what I'm going to have to do to hook up the throttle cable and kickdown lever? I saw that Holley has some Chrysler adapters:
http://www.holley.com/20-7.asp
http://www.holley.com/20-67.asp
Looks like this allows the accelerator cable end to hook to the carb, but I'm still not sure how the accelerator cable housing is secured to the manifold or how the kickdown lever hooks up. I've seen that Bouchillon stuff mentioned, do I have to have that to replace the existing kickdown, or is there a way to use the stock one?
On another note, can someone confirm that the 318 poly uses the LA engine timing set? I think I've read that before but I want to make sure before I order one. Thanks.
