Swapping out amp gauge for voltmeter
james133
9:09 PM
new york
I upgraded my wiring harness, and also the alternator doing so the meter no longer is compatible with this set up. I have to switch to a volt meter gauge any suggestions on what gauge will go right into the stock rally cluster ? Thanks. Is it also plug-in play or am I gonna have to wire it own power power and ground
I have seen threads where fellas took the factory amp meter out and put in an aftermarket voltmeter reusing the original gauge face. Let me see if I can find the thread.
I just had mine converted by Auto Instruments. They redid my whole cluster so I just opted for that also.
It was a sticky thread in the electrical forums. Found this writeup on how to convert your Amp gauge to a Volt meter.
I used Sunpro 2" Voltmeter CP8205. Took it apart and everything fit right in my standard dash.
