- 10:29 PM
- Mar 10, 2010
- Hanover, Pennslyvania
It's 2-1/2Kid, is that 2 1/2, or 3 inch?
I think I will cheap out and get pipe and elbows from Napa, and turn them down in front of the axle. I did my Hemi that way a couple years ago. Good enough for me!Added up the parts, just under $350. I guess that's a cheap exhaust system now days.
I use to install them every week back in the day, and the pipes were already made for the car. Plus it was on a lift!
Super nice work Kid, you can work on my car anytime!!!Got the headers all plumbed up this week. Word of advice, don't measure anything when doing one yourself. The engine sits off center and cocked, one header is longer than the other, the tunnel is two inches off center in the floor. I was trying to figure out how one half of the system wasn't looking like the other. That's why! So just wing it, throw the tape measure back in your tool box.
Bought the X pipe, mufflers and misc. pieces from Jegs. Bought the tail pipes from Summit.
Mocking up everything, cutting where ever to make it work out. Then just tack weld to move on to the next piece.
View attachment 411069 View attachment 411070
Then I took it all apart to weld on the table, instead of trying it on my back under the car. I need a lift!
Useing galvanized pipe, sand or scotch bright where your going to weld first. Makes it a whole lot easier to weld.
You have to think about what you're going to weld first. Having everything tacked good, welding where it doesn't have a "pulling" effect on your piece. Use a couple of clamps will help too. You don't want it to pull out of shape.
View attachment 411073 View attachment 411074
Then I cleaned the welds, wiped it all down with thinner and gave it a coat of high heat paint.
Now that's What I'm Talking About! Looking Fantastic Kid!!Some updating. Life has been getting in the way some but this is what has been done lately.
I dropped the old gas tank and didn't want to install the new one with all of the undercoating that's in this area. Might be a little risky useing a heat source around the tank after it's installed.
Here's the link for the tank removal.
http://www.forbbodiesonly.com/moparforum/threads/1962-gas-tank-removal.128773/#post-910648048
Quite nasty with all of the undercoating.
Glad I bought a new tank, ect.
The filler tube is really crusted with rust and just cleaning it up isn't going to be good enough. It will rust again and contaminate the tank.
I ordered a new one from Megan Parts. They were out of stock and didn't tell me. A couple of emails and they now have them and one is on its way.
https://www.megapartsusa.com/proddetail.asp?prod=183-FT6265B
Back to scraping undercoating! I'm just doing the frame rails on both sides of the tank and the floor in that area.
I'm finally done getting it scraped off. Now on to sanding and wiping it down with thinner. It looks like brand new under the coating!
I know it can be done but haven't heard of anyone on here doing it. Maybe start a thread on it.Very clean looking underneath all that undercoating. I've got to clean all the undercoating off my 64 Savoy project. I'm not looking forward to that at all. I'd like to just have it dipped, but a couple of painters I talked to ran away screaming. So I'm guessing that's not a good idea?
I bought one from Classic Industries. It's thick rubber and it has a little weight to it compared to the original one. Hope it works out ok.Don't forget the replacing the pad on top of the tank! Squeak possibly avoided.
Okay,... Now you're just showing off!! Just Stop It!! But it is a beautiful thing!!
Actually it's zinc plated. True galvinizing isn't done very much anymore. (EPA)Is the new filler tube stainless steel? Looks too shiny for being plated. Nice!
Yeah.... we sell stuff Cheap here in Wisconsin!Actually it's zinc plated. True galvinizing isn't done very much anymore. (EPA)
I looked for a place to recoat mine and all I found was chrome plating. The nearest zinc plating wasn't too close to me. Then I saw these at Mega Parts. For $65 you can't go wrong. Then I didn't receive any shipping info from them, so three days later, after an email, they tell me I should have received a back order notification. Here we go again! Just went through this with the trans mount. But they came through and it's a good looking piece, half the price as the other one I saw and who knows what it would have cost to replate it. It's a wonder anyone even has these!
