I give up on it & I think it's time to replace it with an Edelbrock Performer carb. For a stock 440, which is the best one to get & who's got the best price?
The Thermo-Quad was available with two primary throttle bore sizes, 1-3/8" and 1-1/2". Flow ratings (CFM) vary depending on the source, but the TQs with the 1-3/8" bores are listed as 750-800 CFM and those with the 1-1/2" primary throttle bores are rated at 800-850 CFM.
I have been messing around with thermoquads on my 340 for a few years now. I started with the 6319(small bore) and it was the original, but it ran rough, mainly I think because of the pitting form corrosion on the top and bottom plates, so I switched to a 6322(large bore) and it runs smooth, but I still have a WOT lag that I cant get worked out, if I could I would stick with that one, otherwise I may have to go with modern carb!just an off the wall question,has anyone used the thermoquads?
i have a 650 eddy on my 440 already and was thinking about playing with the quad.
i have 3 or 4 laying around,and was debating performance value.
What's wrong with the original?
Replaced the metal valley pan gasket and glued it all together with extreme prejudice.
My restored AVS has the Edelbrock floats in it and I have had them leak fuel and fill the floats twice so far. I still have one that won't leak any of the fuel back out. It sealed itself back up. Cue the Twilight Zone theme.I think I've made my thoughts on Edelbroke carbs pretty clear.If you're gonna buy one, get yourself a supply of gaskets as you're gonna be opening it up again and again to adjust those DAMN floats. Like Carters, these things are susceptible to heat, even with spaces, and those brass floats are mounted using thin brass strips that I suspect warp as they get hot and cool off.
while your at measure the i.d. of the idle tube (the small brass tube attached to the primary cluster). it will need to be at least .035".Got the (internal) mixture screws out finally. What a PIA. I'll throw it back together & try it out this evening as one last shot.
if a float "leaks" it's full of fuel and won't control flow, or are you referring to empty fuel bowls?My restored AVS has the Edelbrock floats in it and I have had them leak fuel and fill the floats twice so far. I still have one that won't leak any of the fuel back out. It sealed itself back up. Cue the Twilight Zone theme.
I had one do that too! It happened right after a tornado went by, and I thought the drop in pressure had allowed the float to open and then close when air pressure returned to normal, but I guess this is an oddball issue with these crap floats.My restored AVS has the Edelbrock floats in it and I have had them leak fuel and fill the floats twice so far. I still have one that won't leak any of the fuel back out. It sealed itself back up. Cue the Twilight Zone theme.
I give up on it & I think it's time..............
