The Long Road to my 74 Satellite Rebuild
rsd-I used to have a 74 RR with air shocks. That photo that propwash posted reminded me of what happened when I used to take it and jump intersections that had a "hump" in the middle. After doing that for a few nights after work, I added a little more speed one night and had good air and when I came down, something went wrong. Got back to the motel and looked underneath and saw that my shock not only went thru the crossmember but also went thru the trunk floor. I ended up taking the car to a welding shop and they made a crossmember from 1/4 in steel and drilled holes in the sides to bolt to the frame. I put new air shocks back on but never did and jumping anymore. I,m not saying that is what you are going to do with your car, but over the years that is something that might happen.
I've heard the horro stories about air shocks and the crossmembers over the years. I've had air shocks on all of my mopars, except one or two, since the mis '80s and never had any problems. maybe because i never did any jumping....:laughing5:
I dont plan on jumping anything!!! LOL, I may just throw some fresh KYB's on there and be done with it. The front ones made a huge difference for sure.
Started prepping the OD transmission to go in the car, didnt do as much as i thought, got distracted by the nice weather.
Hooked up the pressure switches for OD and lock up
And cut the case of the transmission, first cut was a little scary.
next ill wire the switches, modify the cross member, and try installing it. Ill be sure to document the rest of the process.
X- 2 Coming along nicely!
Pulled out the old transmission today. And got the new one ready to install.
Got the OD/Lock up pressure switches wired in
And made a plug to fill were the crank senor was
Tomorrow gonna try to put the 46RH in tomorrow, need to get a flex plate, looks to be the same size as a 904, i have two but one has the wrong crank bolts and another has a bent ear. So hopefully a local shop will have one.
It is in!
I got the transmission installed on wednessday, yesterday i made the bracket with my uncle and today i bolted it all together and started hooking everything up.
Wasted 7 hrs on tuesday trying to using a borrowed transmission jack that was a POS and way too small. Trans almost slipped off twice. Bought a better one that night and had the transmission installed and bolted to the engine in less than an hour wed morning. Like my dad says, right tool for the job.
Here is the tunnel dent i made in order to clear the pressure switches for the OD/Lock Up. It ended up a little bigger than it needed to be in my frustration with the other jack..
This is the jack i ended up using, it really worked great
Had to shave another part of the case to clear the torsion bar cross member.
Close up
From the back
Next came the bracket, alot of guys where using a flat style gm mount, but my uncle was pretty sure that he could find a way to modify the original mount to work. We cut the "ears" off and lengthened them.
Here is the modified bracket after its been welded and painted black
Then after a couple trial and errors we determined he had to widen the holes on the bushing, which he did by cutting and welding some washers on to the base.
Then i just had to install it in the car, its a tight fit but it fits and looks awesome,
Still hooking parts up so but hopefully fire the car up again in a couple days. Still have attach the shifter cable, cooler lines and the run the wires for the overdrive. Oh i also had to shorten my drive shaft by 4 inches and i was already running a kick down cable on my 727 so that transferred right over.
Your uncle did a heck of a job with that tranny cross member. Cruising with that OD is going to be nice. You'll have to let us know how it feels when you get her on the road.
Ya he's really good at creating/fabricating stuff like that. I cant wait to try it, ill definitely let you know. Today i pulled it in and out of the garage, but my shift isnt hooked up yet so i cant go to far.
Wow! That's amazing work you've been doing, getting closer for sure!!!
Thanks! Ive still got to figure out where to place my aftermarket shifter so it will fit the factory center console. My uncle said he was gonna start on the body work for the front of the car this week excited to see how it turns out. Also considering the idea of doing my stripes with a faint dark carbon fiber pattern, another one of my uncles ideas. I think it would work with all of the other modifications ive done on the car so far.
Modification of the front end has started. My uncle is taking an inch out of each side of the bumper, and also building a flair to streamline its shape into the fender. He also rounded the corners of the marker light bezels, and we might take the ridge off as well still deciding.
Uncut passenger side
Heres what hes got done so far on the drivers side.
He also squared the end of the bumper to make it flow into his flair better
The front brackets for the bumper didnt have to be modified at all, still mount the same
Had to head back to work a week or two, but was abple to have my bumper inners and brackets sand blasted before leaving. My uncle says he should have in all in primer by the time im back. Very excited!
The car must have been in some kind of accident before we got it, every thing in the front was shifted to the drivers side slightly and the passenger side front bumper bracket was pretty far out of whack. Luckily my donor car had a good one.
The rear bumper had pretty good amount of rust where the inner support mounts.
Here are a few pics of the chopped rear brackets.
Haha it seriously does but i am beyond excited to see it all one color. And i havent driven her since Jan when body work started so cant wait to get back on the road.
Like what your doing with the bumpers and OD, can't wait to see it done.
