padam
What is the thickness of that flywheel?130 is correct... 440-6 assuming it has the stock big rods doesn't take much weight on the flywheel.. Typically the original will have metal removed from the heavy side.... Picture attached...
On an aftermarket flywheel a machine shop normally drills holes to remove weight... Drawing attached..
All of this assumes the heavy rods are in the engine.... Lots of engines get built without them... What does your harmonic balancer look like?
