1970DCH
I completed my TKX swap (I will post a more thorough write up in due time with my experience) but I have an RPM related vibration. I’m hoping someone here might have some input before I pull the transmission out to inspect the rotating assemblies. Basically, I have a vibration that gets worse the higher up the RPM I go. It is NOT speed related and in fact, very smooth at all speeds at lower RPM, ruling out driveshaft issues or pinion angle issues.
Has anyone experienced this using a kit from SST? My engine is an internally balanced engine and the related parts are correctly 0 balance for my application. I’m kicking myself to not have checked the parts, but instructions did not mention that I needed to do this.
Is there a way I can test/ rule things out?
- I’ve confirmed that nothing is hitting anywhere.
- I’ve confirmed that it is not speed related, but RPM related.
- I had triple checked my runout calculation
- I had triple checked that my pilot bearing was seated properly.
- everything torqued properly.
- no issues with installing the transmission to the bell housing.
- my engine is firing on all cylinders.
- there is no clutch slippage or juddering.
- Am I just dealing with a faulty flywheel/ pressure plate, most likely? I’m pretty disappointed to have to pull it all out at this point…
