70rrclone
I have a motorhome 440 that I want to throw some pistons in to get the compression up for a 70 Satellite I'm building. The pistons are Wiseco flat tops.
Heads trick flow 240s. The flat tops are currently. 044 in the hole. (2.05 ch) with a .027 cometic gasket im getting a quench of .071 with a compression ratio of 10.1 I know this quench is ineffective. If i deck the block to get .013 deck clearance that will give me .040 quench which makes the compression 10.84. Most of what i have read said that is too high for the street even with 93 pump gas. Can someone here smarter than me offer some advice?
The car will be mostly hot street with a few trips down the track.
440 auto 354 gear 275/60/15 tire
Performer rpm intake
Sft camshaft No specs yet
Shane
Shane
