Tools-----tools---tools
str8blkj01
4:21 AM
diego
First on the chopping block
ESAB pcm875 plasma cutter $1k
I have a brand new plasma cutter thats just been sitting around. never been used i took it out the box and that was it... runs off 220v and could cut some pretty thick metal.... the one at my shop is great thats why i got this one but never had the chance to use it....
Its well worth 2,000 new but I just want it gone for 1,000.....
Again brand new with all instructions and paperwork
http://www.esab.ca/literature/Plasma...-E_PCM-875.pdf
From esab:
ESAB PCM - 875 This air-cooled package is the ideal solution for fast powerful cutting of thicknesses up to 10 mm (separating cut up to 25 mm). The PCM-875 works with compressed air and the variable output power from 15 to 50 Amp?re enables exact setting of the cutting power for all sheet thicknesses and applications. The PT-20AM high performance torch has a patented design of nozzle with long-life consumables for reduced operating costs.
Components Power source, hose set, ignition box, PT-20AM torch. Technical Data Current Capacity max.50 amps @100 % duty cycle Plasma/Cooling Gas Requirements 350 cfh @85 psig (air) 40 and 50 Amp.Cutting Data (Mild Steel) Output: 50 ADC @120 VDC @100% Einschaltdauer Input: 208/230 VAC, 1 ph., 50/60 Hz, 26/24 A/ph. 400/460 VAC, 3 ph., 50/60 Hz, 13/11 A/ph. 575 VAC, 3 ph., 50/50 Hz, 9 A/ph. Efficiency: 90% typ. Power factor: 92% (400/460/575 VAC 3 ph.) Dimensions: 10 in. (254 mm), wx 20 in. (508 mm), hx 18 in. (457 mm) d Weight: 87 lb. (40 kg) Air requirements: 150 l/min. 4,5 ?5,2 bar
Makita Cordless impact wrench
Equipped with Electric Brake
9.5mm(3/8")
Model # 6907d
Brand New Over 200
First 125
Next:
Dewalt Cordless saw with a package of blades
x2 batteries
x2 chargers
Used acouple times no issues
New together over 300
First 200
