69 GeeTeeX
Today I received my new 9.5” torque converter built by PTC. Engine has a new Eagle crankshaft with new B&M flex plate. When I checked the converter hub fit into crankshaft it was good. After installing the flex plate I rechecked the converter hub to crankshaft and noticed with the hub engaged all the way into the crankshaft there’s about .100” - .150” gap between the converter lugs and flex plate.
Am I supposed to use a washer between converter and flex plate with the 7/16 bolt?
Should the converter hub bottom out in crankshaft or have some space?
505 engine with 727 transmission.
