4mulas
- 1:47 AM
- Mar 16, 2017
- Just North of Great Falls
Going to install my bars,
Arms are hanging, upper c arm stop removed. Pivot bolt nut not tight, same with the strut rod bushing nut. The pivot nut was tightened just enough to suck the pivot shaft tight to the cross member and then backed off, strut rod bushing nut just barely compressing the rubbers.
Question: roughly how far out is/should the adjuster bolts be below the arm and where should the arm be ‘clocked’ to when installing the torsion bar.
Thank you!
Thank you!
