MikeBarn
I know torsion bars are often discussed. I've searched as many places as possible with no luck or answers.
I'm trying to raise the front of my car. I've tightened both passenger and driver side 3/4" nuts on the end of the rod, by the LCA. On the passenger side I was able to get 2 full turns. The drivers side wouldn't tighten at all. I sprayed both sides with PB blaster and I'm using a 1/2" socket with a breaker bar. There's only about 3/8" of the thread sticking out the back of the nuts. I also measure the distance on the driver side from the ground to the top of the wheel opening and its 27.5".
Do I need an impact wrench to get these tighter?
Do I need to replace the bars?
Do I need to loosen the nut on the front of the bar, near the K member?
Any help would be appreciated.
