Trac-Lok vs Powr_Lok ?
ITS A 72 RR
12:20 PM
Florida
Can someone tell me the difference between these 2 diffs. I found in the trunk a N.O.S. shipped from DANA to Chrysler with a Dodge model 60 9 3/4 differential case assm. kit. PN#27168-3X But it says it's a Trac-Lok. Will it work in my RR ? I'm not a wrench by any means so any help is always appreciated.
RM23:
Plymouth Belvedere,Satellite
Medium, Road Runner
2 Door Hardtop
U2R: 440 280HP(net) or 290HP(net) 1-4BBL 8 CYL
1972
Windsor, ONT, CAN
316877: Sequence number
E86: 440 cid 4 barrel V8 (High Performance) 375hp
D21: 4 Speed Manual Transmission
LV2: Hemi Orange Exterior Color
C2X9: Trim - Charger, Vinyl Bench Seat, Black
TX9: Black Diamond Int. Door Frames
504: Build Date: May 04
282053: Order number
LV2: Hemi Orange Top Color
U: USA Specifications
26: 26in Radiator
C12: Unknown
J45: Hood Tie Down Pins
M21: Roof drip rail moldings
N23: Electronic Ignition System
N41: Dual Exhaust
N85: Tachometer
R11: Radio Solid State AM (2 Watts)
END: End of Sales Codes
Depends on the size and axle splines.....but, the Power Lok imo is a much better unit than the Track Lok. The PL has internal clutches (inboard of the side gears and the TL has it's clutches outboard of the side gears. The PL is also a split case design and the TL is a one piece design and is cheaper for the manufacturer to make than the PL.
