tranny info.
re330
3:01 PM
quebec trois rivieres
so im new to these cars. what where the tranny's for them? there seams to be bb tranny's and sb trannys?
727A fits small blocks and the 727-B fits the big blocks, 727-RG bolts to the six-cylinder blocks. The 904 comes in a 904-A, 904-RG, as well for some of the earlier 4-cylinders. Some higher performance 904 units were designated as 998s and 999s in the later 1970s.
Exactly.
Also to keep in mind the 727's are longer than the 904's. For a B body example the 727 is the same length as an 833 4 spd. but the rear mount is farther back on the auto so you will need to modify or get the appropriate cross member if changing over.
