trans 727 caps
ruben167
New Member
1:01 PM
italy
Hi guys, I have a 727 trans and I noticed a kind of plug on the back just above the oil pan, could you tell me what it is?
Pressure tap for the low/reverse servo. There are 4 taps total. 3 in the case, 1 in the tail housing.
Low/reverse apply arm pivot pin.
Or it he could be looking at the rear band pivot axle?
Mike
Oh thank you do you happen to know how to replace it because when I cleaned the transmission I noticed that the cap was hidden by black paste because it was probably leaking
Is there a little piece of the extension housing that hangs over the "cap"?
Mike
I think we are talking about two different items. If it had rtv you are probably talking about the rear band anchor pin. It has a o-ring. Leaks are common. If the pin is pressed all the way in (lightly tap on it with a punch) and has been well cleaned. Then a small dab of rtv will seal it without disasembly. If its already apart replace the o ring. Later transmissions have double o rings on the shaft.
