padam
For you big HP guys.
New announcement on Facebook:
I would think they would pretty much have to be, or maybe even require their own dedicated intake?? Possibly kits to make sheet metal intakes maybe.....And if they'll be max wedge ports.
All the big heads are MW port window. ( except B1 I guess). These appear to be a CNC version of the 270 with bigger intake valvesCool - I thought the 270's were already MW ports?
Makes sense. I have the TF 240's on the 505 in my Cuda. Nice heads and needed nothing out of the box.All the big heads are MW port window. ( except B1 I guess). These appear to be a CNC version of the 270 with bigger intake valves
Not sure what you mean. This is about TrickFlowNo mention of Indy heads?
Mike
Wonder how much they would cost? And if they'll be max wedge ports.
The 270’s are max wedge so these are too. The 279s are $1500 each, so expect these to be more. Unless your building a rocket the 270’s would be all you would ever need. The 270s have a peak intake flow of 352 CFM, which should easily make in the 700-850 horsepower range in a 500+CI engine, depending on the rest of your build.Cool - I thought the 270's were already MW ports?
Off-topic, but i do love my -1's yes.No mention of Indy heads?
Mike
Have to agree. They're just good.Off-topic, but i do love my -1's yes.
Yes, the j converters were built for that. We can't tell you what's inside the trans though.This is going way off topic, but with a motor pushing 700 horsepower. Would my old school j converter be good? And my transmission has a full manual valve body. Is there anything I need to do to make it handle the horsepower? It will mostly be street driven with maybe a handful of track times.
Well as far as I know , other than the full manual valve body its a stock transmission with good parts in it to handle 700 horsepower. Stock input shaft, stock sprag.Have to agree. They're just good.
I think it will hold up, provided your traction is limited. With slicks it would be wise to install a bolt-in sprag and a billet front clutch retainer.Well as far as I know , other than the full manual valve body its a stock transmission with good parts in it to handle 700 horsepower. Stock input shaft, stock sprag.
