Trick Flow 295 Heads
I am curious to see what peoples on track results are when they start buying these heads. TF makes good stuff. Little hard to believe these dyno numbers with only a 295cc intake port size. But time will tell!
Seems like a small exhaust valve? Isn’t the common upgrade for oem heads and some aftermarket stuff to 1.81? Does that not matter if they used the real estate to improve the port?
The exhaust port on a trick flow takes a quick turn compared to other bb heads. They get the exhaust out very efficiently. I was questioning it until we put them on a flow bench.
I would trade a larger intake valve for a smaller or oem sized exhaust valve every day. I think intake valve size is more important to make hp than exhaust valve size.
All the big heads are MW port window. ( except B1 I guess). These appear to be a CNC version of the 270 with bigger intake valves
In their post touting the new 295’s, someone asked if the 270s could be taken out to the 295 port size. The answer from TrickFlow was No, it’s a completely new casting. They also said they are recommending currently available HS rocker gear. But they didn’t verify which set. One can only assume they take offset rockers.
The other big news was the new R-series intakes. Which are 4500 flange MW / 270 port size, and they ARE offering a B-series version. Finally, an option to the Indy 400-2.
1970 PLYMOUTH Trick Flow Specialties TFS-61600117 Trick Flow® R-Series Intake Manifold for Big Block Mopar | Trick Flow Specialties
Thank you. That makes it interesting.
As far as exh valve size, they started at 1.60, went straight to 1.88, and have been dialing it back for 60 years. Testing doesn't lie.
I'll be really curious to see how the 295's perform when they come out. I compared the flow numbers and the are very close to my Larry Smith ported 270's with my 270's having similar mid lift flow numbers and carrying out a little better at the top. My exhaust numbers look a little weak but weren't flowed with a pipe so I figure everything there is probably 20-30 cfm higher than what's listed. I am currently having the motor done by Mike over at B3 and will have it dynoed when done. I'll post results when complete.
