Canadian1968
There has to a problem somewhere . I don't think it is the carb. Your carb is set wrong obviously but that because it's trying to cover up the real problem . The motor.has been rebuilt and some thing has changed somewhere . The problem DOES still sounds like a vaccum leak. The question is where . I would eliminate the carb since you have tried so many ,.can't see you making the same mistake over and over with the carb. But work your way down. Check intake bolts, valley pan position , does it have power brakes check vaccum connections and lines . Also set your timing correctly move it to where it should be don't diagnose with it set at 40.
You say it clears up as soon as you hit the gas so hopefully that counts out anything major internally or crossed plug wires .
