rakort
so originally the pump slipper rotor was held to the shaft with a key and a constant cross section retaining ring (similar to a snap ring) and that ring got ate up during the operation of the pump. Probably one of the weak points on these pumps. So I've got a snap ring that fits well, but still not "tight" in the groove so it will rotate under operation and likely get ate up again. Was considering skipping the problematic snap right and using some modern technology retaining compound (loctite) to retain the rotor to the shaft. Thoughts?
Once I solve this issue the pump will be good to go.
