Turn signal
Thackdaddy
1:17 AM
Indiana
When I turn my right turn signal on both tail lights flash, everything else is functioning correctly....thoughts?
Sounds like a poor or lost ground. A jumper wire to check is handy. Also check the bulb sockets for corrosion.
My 65's column switch went bad. It led to no brake lights and no rear left turn signal. I pulled the steering wheel and replaced the entire switch. Of course this was on the tail end of about 30 hrs of tracing wires from a wiring diagram.
But working fine now.
Check your turn signal switch if everything aforementioned is ok.
The sockets are pretty bad and will need replaced, I did the jumper wire and the problem corrected and the bulb brightness was much better.
