JR_Charger
This guy says he's figured out the tech behind the MH 370 orbs.
Lockheed Martin's compact fusion reactors utilizing inertial electrostatic confinement fusion represent the technology behind the MH370 orbs, according to this analysis; this system, patented in 2014, employs revolutionary concentric superconducting ring magnets arranged like "curtain rings on a rail" that create magnetic fields strengthening with distance from center, forming a "magnetic bottle" capable of plasma confinement 2,000 times more effective than publicly known systems.
The propulsion mechanism exploits the inherent flaw of this fusion type - ion ejection along a single path - converted into propulsive advantage; the orbs function as modified turbojets where traditional combustion chambers are replaced by heat exchangers that extract fusion reaction heat to generate electricity for propulsion, explaining why these objects appear relatively cool (blue) despite fusion temperatures reaching hundreds of millions of degrees.
The visible dark lines before and after orbs in the videos correspond to air intake and exhaust flows from this propulsion system; the ability to selectively "turn off" rear exhaust - observable in sequences where only frontal lines persist - demonstrates sophisticated magnetic control allowing field modulation to block expulsion while maintaining frontal suction.
This technology, initially announced by Lockheed Martin Skunk Works for 2019 availability, then pushed to "mid-2020s" before disappearing from public discourse, utilizes hybrid magnetic configurations combining cusp geometry, field reversed configuration (FRC) with helical induction, and magnetic mirrors at endpoints to prevent axial particle escape - an approach enabling plasma self-confinement while maintaining exceptional stability.
