UFOs or UAPs are real
This guy says he's figured out the tech behind the MH 370 orbs.
Lockheed Martin's compact fusion reactors utilizing inertial electrostatic confinement fusion represent the technology behind the MH370 orbs, according to this analysis; this system, patented in 2014, employs revolutionary concentric superconducting ring magnets arranged like "curtain rings on a rail" that create magnetic fields strengthening with distance from center, forming a "magnetic bottle" capable of plasma confinement 2,000 times more effective than publicly known systems.
The propulsion mechanism exploits the inherent flaw of this fusion type - ion ejection along a single path - converted into propulsive advantage; the orbs function as modified turbojets where traditional combustion chambers are replaced by heat exchangers that extract fusion reaction heat to generate electricity for propulsion, explaining why these objects appear relatively cool (blue) despite fusion temperatures reaching hundreds of millions of degrees.
The visible dark lines before and after orbs in the videos correspond to air intake and exhaust flows from this propulsion system; the ability to selectively "turn off" rear exhaust - observable in sequences where only frontal lines persist - demonstrates sophisticated magnetic control allowing field modulation to block expulsion while maintaining frontal suction.
This technology, initially announced by Lockheed Martin Skunk Works for 2019 availability, then pushed to "mid-2020s" before disappearing from public discourse, utilizes hybrid magnetic configurations combining cusp geometry, field reversed configuration (FRC) with helical induction, and magnetic mirrors at endpoints to prevent axial particle escape - an approach enabling plasma self-confinement while maintaining exceptional stability.
Well, you're not wrong, but as far as I can tell that "comet" does have some non-comet like properties; and NASA isn't releasing good pictures of it.
So it's spewing out nickel (mentioned in previous video) like it's a rocket, and there's a claim that it's changing course at a rate that would be tough to match with a rocket, and we still don't have good pics of it from NASA. And now it's hiding behind the sun. Most likely it will turn out to be a rock with strange properties, but let's raise shields and arm photon torpedos just in case.
Full impulse power, Mr. Sulu!
Sidebar comment
Maybe it is my age or what is going on in my life, maybe it is just how youtube people are, but I get SOOOO irritated when there is someone with some type of news and they make a 20 minute video.
here is the thing: how do I know they are milking it out and talking to F'ing slow? I can put playback speed at 1.6x and have zero issue understanding anything they say.
many times I can put the play back at 1.25 and it sounds like they are speaking at a normal pace. I wonder if they slow the video down to extend the play time youtubemoney? I have no time for that ****.
Anyway, thanks for the video. I am at 1.75x playback to get through it before bed, but thanks for the interesting video none the less.
I know exactly what you're saying. The ones I really hate are the ones that have to give an 18 minute history lesson before spending 10 seconds on the part I want to know about.
Anyway, it crossed my mind that 3i/Atlas could be the answer to why you're still seeing spraying. Bit of a stretch, but if this is an alien device that can launch multiple Carrington event level solar storms at us, over and over again, maybe we need some heavy metals in the sky to protect our electronics. Just spitballin'.
3i Atlas is looking more and more like an artificial object. I'll throw out a wild guess - someone just showed us who the boss is. 3i Atlas is a weapon that launches solar flares at enemy planets. It went to the other side of the sun and set off a few flares as a warning before moving on. Elon observed that 3i Atlas would be a heavy spaceship - the weight is in the mechanism that initiates the solar flare.
Or, it could be the strangest rock we've ever seen.
Summation - either 3i Atlas has blown to bits, or it is technological (comments say it's still in one piece). Supposedly, it's now on course to take it to a mysterious proto-solar system that had it's proto-planetary disc vanish over a few years, which should be impossible. The Angry Astronaut has a theory that a machine civilization harvested the proto-planetary disc to make 3i Atlas probes. That's speculative, but it's a "working theory." We don't know what's going on.
M. Jäger, G. Rhemann, and E. Prosperi caught the interstellar object in a photo and wrote on November 8, 2025, at the Facebook page ICQ Comet Observations: “3I/ATLAS showed a complex tail structure early this morning. We observed it at 29 degrees elongation from the sun … At the time of exposure, the comet was 7-10 degrees above the [eastern predawn] horizon. At the end, twilight interfered with the observation, which took place under bright moonlight. We observed from a mountain location.” Image via M. Jäger, G. Rhemann, E. Prosperi
| EarthSky
