Glenwood
- 12:04 PM
- Jun 19, 2015
- Kawartha Lakes, Ontario
Has anyone installed aluminum heads on a stock bore 383 or 426W (4.25") without clearance issues?
I've been contemplating going to aluminum heads but I can't determine if I will have clearance issues with the cylinder walls.
Trick Flow 240 for example has a minimum bore size requirement of 4.32”. They have a large intake valve of 2.190 and an exhaust valve slightly bigger than stock at 1.76, whereas most of the other brand aluminum heads I've found have a 2.14 intake and a 1.81 ex.
I know that the max wedge blocks were notched for the large 1.88 exhaust valves. I don’t know how the cam lift values play into this tolerance, but my cam has lifts of .494I/.513E.
I’m interested in the promaxx 9440 which uses the same 2.14/1.81 valves but I’d hate to shell out a couple of grand (CAD) for heads & gaskets to find out they won’t work.
