The bracket to mount the compressor is from Bouchillon Engineering. When I bought my system from Classic they were well aware of it and just substituted it instead of the standard brackets for a small price difference. But I don't see why you couldn't use it with either a Classic or Vintage system.  Note that (a) the bracket requires an electric fuel pump because it puts the compressor where the mechanical fuel pump is mounted and (b) it is a finicky pain in the arse to get right so the belts don't squeal. Once it is set right, it works well, but you can't just throw belts on it and expect it to work well. I hid my compressor due to my air grabber system - I didn't want to detract from that. But if you can mount the compressor in a more standard location, it will make for an easier install. So do you want better looks or more simple setup? Everything has pros and cons, so decide which you prefer!
