WCFB carb repair
Belvedere One
5:14 PM
Phoenix, AZ
Looking for someone or a carb shop to rebush a throttle shaft in a WCFB. I've noticed fuel leaking out of the right primary throttle shaft immediately after fuel leaves the squirter. Not looking for a full rebuild just drilling/reaming and installing a new bushing
If the engine is not running raw fuel will wick out the throttle shafts. Its not a sealed area.
It runs fine. I can agree to a point that fuel may wick from area but this is an all out running flow from just the volume from the squirter. I've never had a carb with this issue.
If it starts and runs fine leave it alone. If gas is not coming out the shaft when it is running I would not be to concerned.
