Coronet 14
Having an issue with dash lights and interior lights. When you turn the knob to the left to what should dim the dashlights it brightens them. IF you turn the knob up on what should brighten them all the dashlights and radio lights go out. Switch would get really hot and blow the 5 amp fuse and the 20 amp fuse. So I got a new headlight switch and when I hooked it up and smoked it. Hooked up the old headlight switch and put a circuit breaker in and smoke started comming out of the voltage regulator. Iv'e figured out where the wires go but haven't found any problems. The headlight switch will get very hot and still will blow fuses. When the switches got hot all wires were cool to the touch. So what am I missing. This is on my 72 Coronet
