Weird Six pack carburetor troubles!
Coronet guy
7:11 AM
Tisdale Sk.
I’m having trouble with my 440 six pack system. I had it rebuilt this year but now I’m having trouble with cylinders 1,2,3and 4 fouling the plugs. This is happening with in approximately 6 to 10 miles. The other plugs are still like new. I pulled all of the carbs off and I took the bowl off the front carb, there wasn’t any fuel in the bowl. The other two were right where they are supposed to be. When I changed spark plugs, it fires right up and works perfectly, but after about 10 miles or so, it starts backfiring, loosing power and runs terrible. I was suspicious that it was trouble with the front carb,so I took the bowl off to check the needle/ seat. They seem to be holding fine, so I removed the float,and stuck it in a dish with gas in it to see if it possibly was cracked or a hole in it. I left it in for about two hours and it seems to be fine, I submerged it several times and watched for bubbles but I didn’t notice any. Does anyone have any advice or information as to what could possibly be wrong with this situation? Any help would be greatly appreciated.
It’s all guess work but sounds suspiciously like one of the carbs (front one it sounds like) is gradually overfilling the bowl and flooding out the boosters after a few miles. Or the fact that the bowl is empty when you check it could be due to an internal leak through the metering plate - warped plate or something like that.
It sounds like the front carb is leaking fuel into the intake for some reason. Thus your plugs get fouled and the front bowl empties after shutting the engine off.
Not sure how that could happen;perhaps base plate screws are loose causing gasket leak,another gasket leaking,something cracked or warped?
Stock metering plates or Promax?
I doubt a failing float would empty the bowl.
Have you contacted your rebuilder over this issue?
Check some of this persons videos.......
If you're a do it yourselfer, a carb repair stand in a pan and using mineral spirits might be a way to test your repair before reinstalling the carb.
Note your needle and seat adjustment height to return to.
Remove the N&S, fill with mineral spirits from there to the bowl sight plug full level.
Verify you have no leak down over time.
Empty the mineral spirits.
Lube and reinstall the N&S to your noted level.
I have flooded my engine when the gasket for the power valve in the center carb was out of place. Odd that an end carb bowl is empty, the stack is gasket, steel plate , gasket and metering plate. Gas should not completely drain out. Keep looking.
i am having nearly same problem only gas fouling 2&3 have kitted center carb front carb not dumping any fuel i have no idle adjustment on main carb
Did these carbs work right before the rebuild? Some of the six pack guys say to run a 195 stat for proper fuel atomization. I can’t run my current car that hot, but have in the past in other cars. I don’t remember what stat I ran in my six pack car.
i mean, is this really a hard and fast rule? i see some 6 pack guys say they run 185 tstat and no problems at all.
I would say no, it's not a hard and fast rule. There are factors that may warrant running hotter than the typical 180F thermostat, but generally, cooler is better than hotter.
That’s what some of the gurus say to do. I dunno. I say skip the six pack if you want to save a bunch of money and have it work good in no time. Some people want that pop, I get that aspect too. I got mine working really well, then had my cars parked side by side one day and decided to try a performer rpm and Holley off the other car and it just killed the six pack. I thought it was running so good until I tried that. Sold the setup and never looked back.
I've ran my six-pac for 40 yrs and never had a problem
I didn’t either, until I put that rpm intake and four barrel on my 440.
Which carburetor did you use with the intake? Stock cam? Thank you
The engine the Six pack was on was some cast crank deal I didn’t build. It idled like a pro stocker. Wild guess would be something like a 484 mp type. Around that time I was fooling with both a 750 vacuum Holley and also an 850 dp. Could’ve been either. I had a few cars at the same time back then.
