Great, where do I buy these rods? Did you say you tiged or stick welded?Sure will! I had a buddy that bought a used boat up here in Illinois.
It was an Inboard/Outboard Mercruiser four cylinder. He found out that
the one side of the block had been pushed out from frozen water left in
the engine. It opened up the whole top of the water jacket just below
the deck bolting surface. Freeze plugs were still intact! I V'd out both
edges and beat everything back with a dead-blow to where it all looked
good. Welded it up with 224 and that was it! So far I've fixed three more
IO's the same way. The owners were told they needed a new engine. Ha!
This stuff really beads up nicely, and is very easy to apply. I'll look for
some photo's and post them.
Kern
keep me posted
I have several C and B Magnum drivers side manifolds
at least I did unless my **** clean up brother scrapped them
last ones I installed was on a late B Body which takes different drivers side than early B-E body D body Imperial takes B body IDK about A body
I thought you were by Kern river and I could drop one off...
cheers
