What’s best? Orig. Mopar setup or aftermarket proportioning valve?
Sonny
It’s all fun til the rabbit gets the gun.
9:05 PM
Florida
I have my engine out and I’m considering switching to a simpler proportioning valve similar to the one below. Original system seems complicated and I’ve read not easily adjustable. What do you guys use?
I have power disc/drums.
Sonny
Sonny
View attachment 1310293View attachment 1310294
Are you having a problem that you're trying to correct? If so, what is it?
Nope. Just thought now is the time to change it with the engine out.
My brake system is a custom bend and build.
4 wheel disc. I installed the proportioning
valve up by the master cylinder. It makes
adjusting the system much easier. If you
we're to do this it would require a straight
thru adapter/connector where your valve
is now. I'm getting old, and crawling
around on the concrete is not really
something I look forward to.
Careful with the valve your planning to
install. Brake fluid will eat that adjustment
knob. (note the aluminum one on mine!)
The stock prop valve is non-adjustable. The other block with the brake switch is useless. Get rid of all that junk and install an adjustable prop valve and a T for the front brakes. If you're thinking of a line-loc, now would be a good time to install that as well.
I REALLY like this setup
I'm using the original set-up on my 72 with power disc/drum. It works great.
No need to overthink or over-do it in my opinion.
Chrysler spent more on research them we will ever see to design a system that works and complied to about every idiot thing the consumer could do. So why mess with it unless you are planning on modifications to the system?
I use the original system used after 1-1–1970 with metering valve. Works great.
