Intake is 413. They ran this on '62 Chrysler 300H. Unfortunately, it does not have matching carbs. Both of these carbs have automatic chokes, meaning they are both for single 4-bbl setup. The 2 X 4 setups had a primary carb with a choke and a secondary carb with no provision for a choke. I once had a matched set on a 1964 Polara 500. My carbs also had the large central brass idle speed nut as early Hemi carbs had. The intake could be worth $500.00 to the right guy. The carbs are not anything special, so are only worth whatever a swap meet carb goes for.
