Paul_G
- 3:50 PM
- Dec 24, 2013
- Surprise, Arizona
This is the 73 Charger I brought home a few weeks ago with an engine that would not run. That problem is solved, now this.
Before driving the car I gave it a once over, replaced brake hoses and bled the brakes, checked the steering components, nut and bolt check on the suspension, did the alignment, check fluids, adjusted the clutch. It was ready for a shake down drive. Had it out, and it was running really good. Got it up to 60 MPH, it started to shake badly and then a great big BANG. I could see the drive shaft rolling down the road behind me. The u-joints were new and freshly greased.
Differential yoke has a strap bolt broken off in the yoke.
Trans yoke has an ear broken off, the yoke itself stayed in the trans for some reason, the tunnel has a big gouge in it above the trans side u joint.
Trans tail housing broken off
Bell housing cracked on both sides
dents in the drive shaft.
