Can you elaborate on this?welded Up lowers
What?marry her young![]()
I was assuming that the op would be planning on changing the box but was just concerned with the brackets and pulleys.No, no it is not "simple as" removing the belt.
PS box is WAY more difficult to turn without assist than a manual box.
Absolutely. I can’t believe that could even be misunderstood. OBVIOUSLY I’d pick up a non-power box.I was assuming that the op would be planning on changing the box but was just concerned with the brackets and pulleys.
"Welded up lowers" is probably what he's referring as welding pre-fab plates to the underside of stock LCA to add rigidity.Can you elaborate on this?
Got it. I thought he meant welding the lowers to make them solid or something."Welded up lowers" is probably what he's referring as welding pre-fab plates to the underside of stock LCA to add rigidity.
