Charlie71rt
What makes a 1971 383 magnum different from any other 383
I am sure Chrysler was disappointed that the hp differences were minimal
I believe there was 3 versions of the 383. You could choose a 383 with 2 bbl. carb and single exhaust. HP was 280 at its highest level.Not sure about 71, but in earlier years there were two versions of the 383. Mine is a 69. I'm sure there are some differences in internals, but there is only 5 hp difference. 330 hp and 335 hp. I have the 330 hp version and it has a four speed and factory air. I am sure Chrysler was disappointed that the hp differences were minimal
yes. 383 was used in a lot of vehicles including those big Chryslers.I believe there was 3 versions of the 383. You could choose a 383 with 2 bbl. carb and single exhaust. HP was 280 at its highest level.
Understand. I had read that sometime back, can't remember exactly where, that they felt there would be more of a difference between the two. If I can find I will post a linkProbably not. Why would they be disappointed with something they designed ? That's the way they wanted it. The mind set of the time was sales. Even in the late 60's early 70's there was a considerable portion of the population that was resistant to high performance culture. Our parents and grandparents. Having both 383 and 440 4bbl engines AND 383, 440 Magnums, you can create a sales distinction. So a 440 in a C body or a 383 in an air conditioned Coronet appeals to a guy who wants to tow a boat and not go to the dragstrip.
Sorry, man...the 383 and 440 all used the same heads and 4 barrel intakes on the Magnum engines as they did on the NON Magnum.Cylinder heads, camshaft, intake and exhaust manifolds are the differences.
Not sure. I’d guess a good bit less.What about torque?
