- 4:06 AM
- Jan 29, 2018
- Midland Ontario, Canada
Well you seem stuck on using it, so have at'r !
Couldn't agree more!Well you seem stuck on using it, so have at'r !![]()
It's already in, he's just trying to feel better about his decision.Well you seem stuck on using it, so have at'r !![]()
On an original differential I really think conventional none synthetic is a must. Same thought process for gear oil in our old four speed transmissions. They require a brass friendly GL4 only. Not a GL4 GL5 compatible. I had to special order straight GL4 just recently, not on the shelves.Yes, I have seen some conflicting information from folks and manufacturers regarding new innards in the differential but is there any info on gear oil changes for the original innards such as my 66 Dodge with open diff? Thanks.
Some of the same type of gains that are realized by using synthetic oils in engines and transmissions for which there is a fair amount of published research.Maybe a better question is,
What are you hoping to gain by deviating from what works perfectly well?
Certainly, wrong viscosity is a bad thing. I'm not sure how that is relevant here. Today's dino or synthetic 75W-90 is perfectly correct to use for yesterday's single weight 90 - better if you have a real cold start.I wish I could remember what he said. Dr Richard Ehrenberg stated in Mopar Action tech articles recently that the wrong viscosity can cause problems. Nothing catastrophic, but problems none the less. Like noise maybe? Just sayin.
Yes, you did - I'm sorry I didn't look carefully enough..."synthetic didn't cling enough, lube the bearings well, or provide enough pressure cushion. I'm sure it was a personal preference, derived from LOTS of experience".I'm not an expert. My friend was. I gave his reasons for not using synthetic in post #10.
i have been using synthetic oils in my differentials , engines , transmissions since the early 90's in every vehicle i've owned and still own ( 1977 F150 , 1972 Mustang ,) and the wife's Liberty , Grand Cherokee , Dodge Caravans etc. she's owned including lawn mowers and snow blowers and have had zero problems -- i have a problem with the previous post statement " not to break in gears with synthetic oil " so could someone please explain to me why ALL the auto companies have been using synthetic oil in their differentials since the late 90's if not earlier . look under that Ram , F150 , GMC , and rear drive cars such as Mustangs etc. and the tag on the diff will say use synthetic oil only usually in the 75-140 weight , i am sure they did not break in the diffs with dino oil then changed it out to synthetic before shipping the vehicle .
This does speak to my particular situation, an old original set of gears, not a new set to break in and in normal use without any hard acceleration or high heat. Thanks for the input.Just had a nice convesation with a very knowledgeable guy from Moser at the PRI show. He said not to break in gears with synthetic. Afterwards no proble. He sais synthetic lubes bearings very well. The gear itself during break in not so much.
Doug
