What would original speedo gear have been for '70 Charger?
Coelacanth
7:12 AM
Edmonton, Alberta, Canada
Just wondering what the number of teeth original speedo gear would've been for a 1970 Charger, 383, 727 Auto and whatever the original tire size was? My car had P195-75-14's when I bought it in 1986 but those wouldn't have been the original tires, obviously. I want to compare number of teeth recommended when changing to 28" tires and 3.55 or 3.73 gears. I would guess all the 727's with the original tires and 3.23 rear ends would've had the same number of teeth speedo gear from the factory?
It looks like a 33-tooth yellow speedo gear would be the correct gear for a 3.55 gear swap and 275-60-15's, just wondering how that compares to whatever was stock.
Year One has a chart and it looks like you are correct with yellow 33 tooth.
Green is a 34 and red is a 35. looks like the 33 is as close as you can get. Most of the time you will be within 4 mph what ever you choose.
If you’re doing a gear and/or tire swap don’t buy a new speedometer gear right away. Do your swap and then download a free speedometer app and go for a drive. Figure out the percent difference between the app and your speedometer as a second opinion to what the chart tells you. It’s just a way to double check before you go spending money on a new speedometer gear only to find out you still aren’t accurate.
Brewer also has a chart.
Thanks, I've seen that chart, but does anyone know what the OEM speedo gear tooth count would've been? Without disassembly of the original, that is?
I don't think I have ever seen it mentioned or in print. Possibly buried in a service manual with a chart for different sized tires that were available and rear gear ratios.
That's something along the lines of what I was thinking. Maybe the OEM gear and smaller diameter 26" tires with a 3.23 rear end might be offset similarly with 28" tire size increase and 3.55 gear ratio decrease. If I knew the original gear, the math would be easy.
Original tire diameter was al 25.3" (775-14) so a 33 or 34 tooth speedometer gear are as close as you can get with a 3.23 gear.
Would that it could be so simple...my broadcast sheet is firmly stuck to the springs and only a complete and exceptionally careful disassembly will let me remove it without major damage...
Thanks for the chart. I'll have to take a closer look at my broadcast sheet and see if I can read it if it's not obstructed by the seat springs...
