- 2:22 PM
- Feb 29, 2020
- Heart of Dixie.....
In one of Nick latest dyno run videos , a 360 magnum , they blowout a stock head gasket somewhere around 5200. I did not hear at what compression ratio the engine was built to, but a compression check showed about 190 on one cylinder.
Most rebuilds for me were mostly stockers and I would just use the supplied Felpro head gasket in a standard rebuild kit with no problems so far. But, I recently put together a 68 440 that has a ratio around 10.24 for a pump gas motor that may be too much. And I used stock gaskets. So, what is the cutoff in compression or cylinder pressure check that calls for stepping up to a performance gasket. thanks.....
