What's the REAL Compression Ratio for Stock 69 440 HP??
The factory warranty program may have paid for the r&d but the problem is the same for any open chamber mopar
remember I'm talking street not race only builds with a narrow high rpm power band
need a wider power band then still works to add some lower end of the power band torque
I built a 440 for a friend. He wanted it near stock with a very smooth idle. Used quench dome pistons. Equalized the depths of all the open area of the chamber. set it at .040" quench. Did the bowls and put 30 degree intake seats in them. Used a small 214@ .050" cam. Stock intake, carb, air cleaner and exhaust manifolds. True 9.7-1. it rattles a bit on 93 octane in the summer at full 36 degree timing setting. Other than that it runs really nice. Should have made it 9.5-1
That’s good info Doug. Do you recall what the cranking cylinder pressure was.
The one engine that I am familiar with is very similar to the one you described in the same mid-west type elevation, but with a 220-ish cam. On the edge at 9.5:1, and blew about 160 psi, IIRC.
Sorry for the Necromancy....but if one wanted to be able to use 87 what pistons would be the go to?
Imo, the ideal piston for a stock iron head big block would be one with a reverse dome to get quench with the open chamber head, and a D-shaped dish on the other side, to get compression where you want it. Some clever calculating will be required, and I have no idea if such a piston is shelf stock anywhere. (I kinda doubt it)
A custom piston might be required to achieve the above.
Or, you simply put a flattop piston way down the hole, give up a bunch of power and torque..... and still maybe detonate on 87. (Especially the 10-15% corn garbage) .
kinda what i was thinking. I think im going to run the Stealth aluminum heads on mine.
Kb 184 piston is the perfect match for an iron open chamber head and pump gas.
Never checked the cranking compression. I was originally shooting for 9.5-1. But my machinest cut the heads a touch to much.
I used the cnc stealth heads on my 76 440. The PO had punched it .030 and did not deck it. He used speed pro 2355 flat tops at .017 down the hole, a .051 fel pro. Topped with stock 452’s, the cam was a small comp hyd. If I remember right 215/220@.050. It pumped 180 and pinged on 91 with octane booster. I had to drop total back to 28 it was a rattlley dog. Bought CNC stealth heads, .039 gasket for alum heads, Isky 292 mega hyd. 240@.050 500 lift. 108 lsa 104 Icl now it pumps 175 and runs 36 total on 91. 11 converter with 3.73 gears. I like it now.
There are many that think the ethanol actually tests higher in octane than pure gasoline with the same rating.
Pure ethanol can be as high as 113 octane, and gas is rather low. The additives to gasoline bring it up, but they're using ethanol to do that in place of other additives. We use the (ron+mon)/2 method, so perhaps ethanol has a much higher ron rating than other additives, thus goosing the numbers we see in the real world.
Rick Ehrenberg claimed that ethanol had a higher octane than advertised yet when he and a buddy drove a 70 Road Runner from New York to California 5 years ago, he wrote of heavy detonation after filling up here in California. There is no “non ethanol “ pump gas here that I know of.
Law in California requires oxygenated fuel. Alcohol is not required, but it's what the oil companies use to meet the rules.
The only non-alcohol fuel in california that I know of is non-street legal leaded race gas. (Oops, not counting Avgas)
I do know of a station that sells 100 octane unleaded out of a pump. Last I saw it was over $12/gallon.
California 91 varies from just under $5, to over $6.50, depending on location.
