- 10:58 PM
- Sep 3, 2020
- Cottage hills Illinois
View attachment 1111617 I have a 71 superbee that first had a 383 in it with air. But know it has a 440 but does not have air. Could not see any numbers on the radiator. Radiator does have cooling lines for trans.The shroud that i found in the trunk numbers was 2785435. 19079 . I'll take a pic when I get home from work. And post it. The mounting holes on the radiator dont line up with shroud. View attachment 1111618
Any clue where a person might get one at ?The numbers should be very obvious, they are stamped into the top tank... What you have is likely a replacement radiator with no numbers....
And your shroud is for a earlier B body (68-70) a 71 uses a shroud with only four attachment screws... like shown...
