I did find the 128 rule and here are the numbers I come up with,You [ & some others ] are paying too much attention to advertised duration #s. The duration measuring points vary, generally from 0.004" to 0.008". Usually tappet lift, but not always..... The Comp is 270* is measured @ 0.006" of tappet lift. Some cams are measured at valve lift. So if you are comparing cams to say the Comp 270, a cam with 270 @ 0.006" valve lift is going to have less adv duration than the Comp because that equates to 0.004" tappet lift [ 1.5 rockers ].
Some of the cams listed above do not list this important info, so useless trying to compare cams that way.
I suggest you find D. Vizard's 128 rule on the web & calculate the reqd LSA [ It will be considerably tighter than 112....]. While it is for SB Chevs, he has claimed it works well for parallel valve heads....certainly better than GUESSING.
Intake Valve size 2.08 with the center line, using this formula, is 105.4 *(LSA) (*edited because center line is the wrong term)
Exhaust Valve size 1.60 the C/L is 98.2 *(LSA)
The Melling cam is 110 and 116.
I read that advancing the cam can lower the power RPM range of the cam. Would that have the desired effect of helping the Melling cam higher than optimal C/L?
And that’s why earlier you mentioned the 110 C/L of the Camcraft cam would be your choice?
I knew that comparing all 4 of cams initially would be like comparing apples to oranges because not all the specs categories are listed the same.
