gdrill
Just enjoying "B"-ing here
- 12:36 AM
- May 29, 2013
426!
Why? Because a 440 has too many cubes!
Yes they will fail if running the 5/20 weight that is recommended.I ran 400 and 440 trucks for decades and they always got me home. These 2 trucks have both had cam and lifter issues as well as the computer bricking on the red one. Please don't tell me how great the new engines are. Lets talk about how easy it is to change lifters on the 2 different style of engines as well.
Yes the lifter issue is a known one with known solutions. It however does not plague the entire engine line and your bad luck is much less common then 150K good runners. A quick search on ebay will show you 5.7L trucks for sale with 175 to 345k miles on them.I ran 400 and 440 trucks for decades and they always got me home. These 2 trucks have both had cam and lifter issues as well as the computer bricking on the red one. Please don't tell me how great the new engines are. Lets talk about how easy it is to change lifters on the 2 different style of engines as well.
I know, that sound thing is so dumb it hurts me to think they actually made it. The car looks nice though.If you do go with a 6.4, maybe stellantis can sell you a "simulated sound module" to make it sound like a 440. Not sure if they sell that but maybe...
Listen to the Dodge Charger Daytona SRT EV's Simulated Exhaust
We're not sure how to feel about this.www.roadandtrack.com
We keep over 161,000 Big Block Mopar parts on the shelf ready to ship to you within 24 hours. Nothing about building a Big Block Mopar should be hard to find if you check out our web store: -440 Sourcetruth of the matter is parts are getting harder to find
I purchased a few things from you guys that I really needed but I mean t like over the counter. You guys are cool but I can’t drive to Vegas and there are some parts that aren’t available like the 402 oil pan I needed that you guys didn’t have at the time. You guys tried but at that time you didn’t have it, you had an oil pan that would have worked but then I had to change the pick up tube.We keep over 161,000 Big Block Mopar parts on the shelf ready to ship to you within 24 hours. Nothing about building a Big Block Mopar should be hard to find if you check out our web store: -440 Source
We do remember that, and we are going to carry the actual 402 pan in the future for guys in your situation where they want to re-use the original pickup, or want the "402" stamping for a restoration... or other reasons similar to that. Thanks for the feedback!I purchased a few things from you guys that I really needed but I mean t like over the counter. You guys are cool but I can’t drive to Vegas and there are some parts that aren’t available like the 402 oil pan I needed that you guys didn’t have at the time. You guys tried but at that time you didn’t have it, you had an oil pan that would have worked but then I had to change the pick up tube.
If you have the time sure no worries but sometimes you need that part right away.
Every situations different and I see your point
No worries. You guys are awesome !We do remember that, and we are going to carry the actual 402 pan in the future for guys in your situation where they want to re-use the original pickup, or want the "402" stamping for a restoration... or other reasons similar to that. Thanks for the feedback!
I am going to rebuild a 440, and I just bought a 413 1962 I think, from Imperial , engine is said to be in pretty good shape.. If I can combine all of my pile of engines, and have heads, went to garage and took a picture of the # on some heads I bought long time ago, 2406518, looked it up, said it was from a 1964 426 2.08/188 max wedge 86cc. well Im not a expert at all, also have one of the purple cams from many years ago, in the box, so hope to put it all to together and have something good, any input on the heads would be great.. have 67 charger 383, 72 Monaco, 71 charger, well body, so any thing?There are usually 450-500HP 440 crate engines that have some sort of warrantee for 9k-11K. Here is one example.
Big-Block Mopar Crate Engines
Another on eBay. I know nothing about these guys, just a 8K+ example.MOPAR 440 ENGINE ASSEMBLY HP HYD CAM IRON HEAD street/strip 500hp ready 2 run | eBay
Then I would guess 4K or 7K to have it installed depending on where your at, if you have all the parts. Putting a 440 back where a 440 was isn’t difficult at all. Quite a few of us on here can do that in our sleep.
The 6.4 swap might be 6K for the engine, does that have a warrantee? Will it make 500HP?You will also need a small block 727 or 904 trans instead of the big block 727, add that to the cost. Then a lot of wiring work, intank FI pump conversion, and hiring the little stuff done for the modern stuff is terribly expensive, probably 4 or 5 times what it would be to put the 440 back it. That is were 10K projects turn into a 100K resto mod.
I will take the 440 over a 6.4 anyway. Our 500 HP 510 with iron heads once averaged almost 18mpg on a 350 mile round trip, with a chit ton of 1/4 mile passes (made it to the finals) averaged into the trip. Well chosen parts 500 HP is a piece of cake. Power is in the heads.
Got my CNC Stealths in 2 days.We keep over 161,000 Big Block Mopar parts on the shelf ready to ship to you within 24 hours. Nothing about building a Big Block Mopar should be hard to find if you check out our web store: -440 Source
My advice: Sell your rare 426 max wedge heads to someone that has an era correct max wedge project and buy a set of Stealth heads from 440 source.I am going to rebuild a 440, and I just bought a 413 1962 I think, from Imperial , engine is said to be in pretty good shape.. If I can combine all of my pile of engines, and have heads, went to garage and took a picture of the # on some heads I bought long time ago, 2406518, looked it up, said it was from a 1964 426 2.08/188 max wedge 86cc. well Im not a expert at all, also have one of the purple cams from many years ago, in the box, so hope to put it all to together and have something good, any input on the heads would be great.. have 67 charger 383, 72 Monaco, 71 charger, well body, so any thing?
Thanks, what are these heads worth, old ones, and how much for the new style. I have the purple cam also, new in box, Have to go and get the #'s DCMy advice: Sell your rare 426 max wedge heads to someone that has an era correct max wedge project and buy a set of Stealth heads from 440 source.
