Babyblue66
Yes I know, I'm not new to this stuff.It’ll do something different than the dyno with the manifolds you know. Still a nice set of numbers and should be lots of fun.
Probably work better with some vacuum secondarys or edelbrock carbs. I had both on a tunnel ram 440. Edelbrock 600s seemed to be the best on the street. Very responsive right off idle, lots of torque. 9.4 to 1, with a hughes 228 232 525 540 lift, headers, porting, automatic.I have a similar 440 low compression motor, the Whiplash 440 cam, but used a tunnel ram and twin 660 center squirter carbs. I would be very interested. It pulls very hard at 3000 right to 6500 (I stopped there).
OK, just thought maybe it wasnt under 3000. But if it work, cool.Thanks for the thought...but it works fantastic, no complaints what so ever.
Yes, it ran really nice. I was going to put it back in but thought I'd try the hughes cam.Babyblue66: Is this the cam you had in it before you swapped it out for the Whiplash cam?:https://www.compcams.com/magnum-224-224-hydraulic-flat-cam-for-chrysler-383-440.html
That's what I have in mine, what I dubbed the "Retardmobile" going on almost 17 years now. I agree, this 270 dur .470 lift cam runs good although it's in a heavy car that is no rocket. Its only a 400 though, with a 727 (2500 stall) with 3.90 gears. Since I also have A/C and power brakes I felt this was probably was about as radical as I could go cam-wise and still keep it drivable.Yes, it ran really nice. I was going to put it back in but thought I'd try the Hughes cam.
Yeah, those are real low compression too. I probably would've gone a little smaller even. But the 2500 stall must help a lot. In my car it had good low end, would burn the tire off easily with just a stab of the pedal. It did run out of steam around 5 grand though. Nice car.That's what I have in mine, what I dubbed the "Retardmobile" going on almost 17 years now. I agree, this 270 dur .470 lift cam runs good although it's in a heavy car that is no rocket. Its only a 400 though, with a 727 (2500 stall) with 3.90 gears. Since I also have A/C and power brakes I felt this was probably was about as radical as I could go cam-wise and still keep it drivable.
Yes the stall speed helps. It's a great car to do burn outs in, lol. It shifts at 5800 1st to 2nd, and I think 5400 2nd to 3rd. Doesn't seem to pull hard after maybe 5500 or so. Since I just leave it in Drive and go, it will never reach the 6000 RPM limit set at the MSD box. Thank you for the compliment.Yeah, those are real low compression too. I probably would've gone a little smaller even. But the 2500 stall must help a lot. In my car it had good low end, would burn the tire off easily with just a stab of the pedal. It did run out of steam around 5 grand though. Nice car.
This is the cam card Hughes provided with mine. Hope it helps.Did you get the specs from Hughes? Just curious as I am contemplating a whiplash cam for my 440 I'm currently building.
Pistons 155 in the hole with a .045 dish. Heads 90ccSome nice numbers for 7.45:1, but I'm wondering how you arrived at that 7.45:1 using a .020" Steel Shim Head Gasket as you stated ?
May I inquire as to how you calculated that 7.45:1 Compression ratio ?
Just say'in....
the Pistons would have to be .170" down hole
and
the Heads were around 95 CC's after rebuild with new valves ?
very true, but this was kind of a cheap experiment. I do have a 9.4 to 1 440 in my 66 coronet. That was all new stuff with a hughes 228 232 cam. It makes quite a bit more power than this low compression 440. It also cost a lot more.The Hughes Whiplash Cam is 229*/242" @ .050, with .518"/.518" Lift
just say'in....
and imo because we've used it and Dyno'd it...... the whiplash Cam is no 'Magic Bullet' for anything ? low Compression is still low Compression....
because....
if you are going inside with the labor and expense of ? and 'rebuilding' a 440 Engine anyways ? Porting/Rebuilding $$ the Cast Iron Heads etc. ?
For perspective only of what I'm getting at....
Here is a much smaller Comp Cam XE274H 224*/230* @ .050 with .477"/.418" Lift used on a .030" over 440 @ just under 10:1 using checked/cleaned up E-Street Heads and a Holley SD Intake.
Notice it never drops below and stays well above 500 Ft/Lbs all the way to over 5,000 rpm ?
THAT.... moves heavy cars...
BTW the xe274 is 230 236 @. 050. The xe 268 is 224 230.The Hughes Whiplash Cam is 229*/242" @ .050, with .518"/.518" Lift
and utilizes the faster .904" Mopar ramps speeds to best advantage, albeit, it requires some at times "iffy" for many V/Springs pressures for break in ?
just say'in....
because....
It can get by just fine.... and breaks in really easy at 110 Lbs seat and 280'ish open pressures using mushy Chebby .842" lifter ramps.
