Mike67
I agree that all the air needs to be pumped out, but if there is not enough stroke to fully engage the rear slide it could be a long drawn out process.
You can look up how much stroke (piston movement) is required and eyeball it from underneath on your pushrod.
I usually used a vacuum pump, or I'll take a clear water bottle and fill it 1/3 off the way with fluid and take a hoses off the bleeder and submerge it in the fluid. When you are bleeding it, it will confirm that air/fluid is being moved in the form of bubbles. The fluid will turn milky, don't stop there, those are very small bubbles.
