will 440 HP factory headers fit onto 70 Coronet 383
Factory Headers?? Factory HP Manifolds yes they will work. Also a lot of aftermarket B body headers will also fit.
Depending on the year of the manifolds, the clocking is different for the head pipe connections.
70 manifolds and 70 car/exhaust should be a bolt on connect the pipes and go. :thumbsup:
I should clarify. This is assuming the car had hp manifolds before. If it had a big block with the “log” manifolds or a small block. The pipes will not connect without reworking the head pipes. But the hp manifolds are exactly the same between 383 and 440.
I can state from experience many moons ago 440 HP manifolds from a B body will go on a 383 C body and OEM dual exhaust bolts straight on.
Which OEM exhaust, for the B body, or C body? I believe that the C body exhaust is unique and will only work with its own unique driver side exhaust manifold.
The HP manifolds came off a 70 Charger RT and went on a 65 Sport Fury. The exhaust was Walker for a 65 Fury 383-4.
Follow up question, is the clocking of '70 non HP or 2 bbl exhaust manifolds the same as '70 HP manifolds?
Edit: I ask because I got '70 330 hp 383 (not 335 hp) manifolds which had the dual exhaust. Were 383 2bbl manifolds clocked the same?
The low-po verses hi-po manifolds are clocked differently
