Window clips with vinyl top?
dodge68charger
8:39 PM
Washington
Are the window clips around the front and rear windows mounted the same height as the non vinyl top cars?
I think i held the clips lower about an 1/8 inch when i had to drill new holes
I marked the locations. Just not sure on the corner hole locations. One says 4 1/4’’ from the bottom corner, one says 5’’and my parts charger looks like its at 4’’ lol
Should the clips sit flush at the bottom or a bit lower is Ok?
Thank you
Just clip heights on the sides/bottom and where you measured from on the corners. Top holes were already there
Thank you!
