wing window u channell rubber. holds vent glass to chrome latch assembly .
66 coronet jeff
New Member
11:37 AM
minnesota
does anyone know where to find a u shaped channell rubber that slides into chrome bar below vent glass on wing window ? it is 5/16" wide outside. glass fits into it on bottom edge of glass. 1/2" tall on both sides. rubber is 1/16" thick max. i have many hours looking no luck.
Hi,
If you are speaking about 68-70 b-bodies, they are not reproduced. They are also left and right handed, I got lucky and had one pair I could remove in one piece.
Good luck,
Mark
To my knowledge this isn't a part. It's glass setting rubber, I forget the real name maybe someone will chime in. Go to a glass company with your channel and glass and see if they can help. And automotive glass co may help as well. As I remamber you use oil or something to help it expand and hold tight. Try resto rick as well.
Good luck
